2 members (Peggy M, Ponchogl),
52
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 85 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 85 | What is the maximum constant speed I can drive my truck without damaging it. What should the RPM be at 60mph? I have a 235 engine in it with 3 on tree Dan | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 60 is probably the limit, under 3000 RPM, less is better for long periods - remember when the truck was new the roads were narrow and poor with a lot of 45mph speed limits
Bill | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Hi Dan I am just up the road from you in Burlington. I have a '51 3100 and before I changed the rear end it seemed to settle in at about 29 mpg. After the change I don't think I would want to do more than about 46 mph. I think 60 would be unobtainable in my rig. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Peter,
What rear end did you change to (from your 4.11:1)?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is the maximum constant speed I can drive my truck without damaging it. What should the RPM be at 60mph? I have a 235 engine in it with 3 on tree Dan If you have the standard 16" tires and the original 4.11 rear-end, the RPM at 60mph would be about 3050. calculator (at the bottom) 4.11 rear end 27.2 rolling diameter of tires 60 MPH 1.00 transmission high gear ratio | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Agree with Tim. I just had my stock '50, 3600 out yesterday and for some reason I was paying special attention to the tach. I say stock but I have changed out the 4.57 for the later 4.10 gear and I've installed a small SunPro tach powered by a voltage booster cube. The tire diameter is the same as the original 15" tires that it would have come equipped with. At 60mph I'm running right around 3000rpm. The motor feels happiest between 2700 and 2800 rpm and I think I could run cross-country at that engine speed all day long. When you consider the slight difference in the gear ratios and the smaller tire size between the 1/2 and 3/4 ton trucks, it would only seem logical that a stock 3100 would be straining at 60 mph. Pete and I drove his stock '52 to KC and back a few years ago and it ran fine at 55mph and got the mileage that you would expect from a stock truck of that vintage, i.e. around 15mpg plus a little. My 3600 being somewhat heavier consistently gets a little less than 15mpg.
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Hi Dan I am just up the road from you in Burlington. I have a '51 3100 and before I changed the rear end it seemed to settle in at about 29 mpg. After the change I don't think I would want to do more than about 46 mph. I think 60 would be unobtainable in my rig. 29 mpg - that seems miraculous | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Hi Dan I am just up the road from you in Burlington. I have a '51 3100 and before I changed the rear end it seemed to settle in at about 29 mpg. After the change I don't think I would want to do more than about 46 mph. I think 60 would be unobtainable in my rig. Something's not right....a 3:55 gearset in my 52 lets me go 65-75 all afternoon (with tall tires and a warmed up 235). 16 mpg was about my average at those speeds.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | some folks don't think about the accuracy of their old odometer and speedo - or that a different rear ratio needs a different speedo drive gear  I'm with Tim, miracles are unlikely even if measured in imperial gallons Bill | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I hear ya Bill. I took mine out on the Queen's highway with a limit of 110 kmh(68 mph)where trucks will push you along if doing less and held my own. GPS is a pretty handy way of determining gauge inaccuracy nowdays.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have heard 55 mph is fine with the original setup. I think that is what Denny said.
I am happy with that. But when I get the moola I will change to 3.55.
But then again, I need to get old blue back together and running
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Talking about max speed without discussing brakes might be a bit short-sighted IMHO. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | 1950 3100 54 chevy 235 235/75r/15 stock rear 216 manifold carter 787s
max speed ever 62.7mph (phone app) down hill 6% grade, tail wind up that same hill 45mph runs good at 50 to 55, above 60, white nuckle
avg mpg 16mpg... fill at same station, same pump, same octane | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Dan, if you can look up your tire size here The Tire Rack you will find the rev/mile. If you multiply that figure by the rearend ratio (I believe stock should be 4.11) you will get the RPM at 60 mph. In my 1 Ton it works out to around 2700 RPM. I do run at 60 mph when required with no problem with my 216, however most of my higher speed driving is done at 50 mph. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The tire diameter is the same as the original 15" tires that it would have come equipped with. DG Denny what size/type tires are your running? | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Lets just say that I wanted to "validate" the size of my tires. How do you measure the diameter. Parallel to the ground or perpendicular? I'm thinking parallel, but I'd like to here your thoughts. I know I can read the markings on the tire and look up the size on line. I want to be able to compare the two numbers to see how accurate they are.
Right now my 58 Suburban, '78 250 six, stock 3 on the tree and stock 3.90 rear, runs at 3,000rpm at 55mph according to the GPS. I have been told "you're running pretty short tires." They are cool looking white walls, but not that great for highway cruising. The speedometer in the truck also reads 5mph fast. So at 55mph on the GPS it reads 60mph. I'm thinking that if I get a little bit taller tires I can correct the reading and get a little better cruising revs.
On a related note, I'm running all stock original drum brakes. The truck stops straight and even. I think the previous owner did a brake rebuild before I got it. It actually drives quite nicely on the road.
Larry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Cooper SRM-II, Radial LT, 8.75R16.5LT. Took another ride yesterday and paid a little more attention to the tach. 2500rpm = 55mph, 2800rpm = 60mph. This taint scientific now, with everything bouncing around at 60 I could be off by a bit and remember this is a $29 tack a 62 year old speedo and not the original tires and not the original rear gear. But it's close. I usually read a few miles per per hour slow when I run thru the speed minders, don't know how accurate they are either.
The best way to figure the tire diameter is where the rubber meets the road. Draw a line on the tire in line with a spirit level and mark this point on the garage floor, roll the truck across the floor till the line makes a complete turn, mark the floor and measure the distance (circomference). Diameter = Circumference over Pi (3.1416).
dg
| | | | | Joined: Jan 2011 Posts: 70 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 70 | I think the miracle was only a typo.. Reads to me that Pete meant to say 29 "mph" with the old gears not mpg.
1951 GMC 250 Open Express 1968 C10 Suburban 1971 C20 Pickup
My Dad told me "Son, never hit a man in anger- unless you're certain you can get away with it"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is sad to hear, 29mph in high gear. We used to cruise 15-20mph faster than that on 2-lane country roads in my '48 1/2 ton panel with the 4.11 rear-end and a tired old 216.
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Denny;
Hooah. Thanks. I'll give that a try.
Larry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | you can run these at 60 all day long. I drove my 53 with a 216 for 28 years that way, still do, but its a different engine. (still a 216) Today though, I am in the midst of installing the 355 gears, then I will be completely confused.I agree you should make sure the brakes are good. You don't really need discs, although they do work better, my uncle had a 69 roadrunner, would do like 160 MPH, all it had was drum brakes. Not saying it was the right thing, but then again they hit a horse doing about 130 in it too....
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | reply to tclederman I changed the rear end to 3:55 and it made a big difference. But, there must be something else missing because there is no way I could go highway speeds. Spring is almost here and I hope to have the truck on the road this year (for sure this time) and I will be able to give him a real run and see he'll do. Also, yes that was a typo - meant to say 29 mph not mpg. Sorry if I confused. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Peter,
Have you done a "time trial" on a highway that has distance markings? If you do, go 30 mph for 10 marked-miles and measure the amount of time it takes. Calculate the miles per hour.
As red posted above, when you change rear-end ratio (and tire diameters), your odometer's MPH will be off.
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I'll take it out when I finally get it on the road this summer. I used my Garmin briefly on a quick road test last year and was doing about 46 mph which I thought was about as fast as I wanted to go safety wise. I used to be navigator for a rally team and am familiar with the speedo calibration run - although that was in the last century and we have now gone metric in Canada. Nothing is simple anymore! | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I did 200mi straight in a day at about 60mph. No speedo back then but I hung with slower traffic on the interstate. Managed to pass some too. My truck ('51 3100) has a mostly rebuilt 216, 3OTT, 4.11 and 7.50x16 tires. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Having 3" more tire definitely helps keeps the revs down for that old 216 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | What is the outside diameter of the 7.50x16 tire? Thanks
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I would say it is about 31" in diameter give or take 1/2" 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | A 31 inch diameter will have a 97.3 inch circumfrence if you need that. | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Curt B. What size "tall" tires do you run in the back? My truck has the stock rear axle and currently has old 28" tall tires. I'm shopping for radials and thinking I should get a little bit taller tire for easy cruising. Thanks | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Mine are 255/70/15's which are listed as 29.1" tall. I bought them before changing the rear gearing and in retrospect I could have gone a bit shorter and still had sufficient highway speed. Personally I find no shortcomings with the stock brakes in as new condition and have no intentions of a disc brake upgrade.
