0 members (),
186
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy seabeebu3, you can eliminate the polarity reversing switch, they are just one more thing in the igniton circuit to go wrong. If you're going to set your truck up negative ground then the wire from the ignition switch goes to the positive terminal of the coil, after it passes through a ballast resistor, the wire from the negative terminal of the coil goes to the distributor. A twelve volt starter should have an extra terminal on the foot switch, this terminal provides the resistor bypass circuit connection, run a wire from this terminal up to the output terminal of the ballast resistor (the terminal that is connected to the coil positive terminal). That should give you a simple common ignition wiring circuit, from your pictures it looks like you need to purchase the correct twelve volt foot switch with the resistor bypass terminal, and a ballast resistor, hope that helps. | | | | | Joined: Jul 2012 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 25 | Couple questions, I'm still using the pushbutton starter the truck came, can I still use thus get a coil with resistor built in so I don't have to place a resistor on firewall? If I need the 12 v pushbutt button, do have a link with one of these. Sorry Im new yo the 46. Thx bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Seabeebu3, you could use a coil with a built in resistor and eliminate the ballast resistor, however you will only have the voltage that the coil puts out for all conditions. A circuit with a ballast resistor provides you with more voltage for starting, and a coil with a built in resistor can only put out the same amount of voltage all the time. As to links, I'm sorry I'm a mechanic not a confusilator guy, and I haven't got around to learning how to do that kind of thing yet. Maybe one of our gentlemen with better confusilator skills would post the link you seek. | | |
