1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93838 12/16/2005 8:53 PM | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I have a 63 Suburban that I swithed from an I6 to a sbc with an HEI dist. I ran a 12ga wire from the pink wire at the back of the ignition to the bat on the HEI. The wiring harness that plugs into the firewall has 3 wires that go to the starter, 1 wire that goes to the temp sending unit, and 1 yellow wire that would go to the pos side of the coil. Where would the yellow wire go now that I have a HEI instead of a coil. Thanks | | |
#93839 12/16/2005 10:37 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Don't use the yellow wire, it is a resistive wire to reduce the voltage to the points (9 volts, to make them last longer). The pink wire you are using is sufficient. You want 12 volts going to the HEI, so that it will work correctly. | | |
