9 members (jupitor, Lightholder's Dad, GMCJammer51, J Lucas, JW51, Tinker5, TUTS 59, wilbur53, 3B),
229
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93823 12/10/2005 6:24 AM | Joined: Nov 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 54 | I'm installing turn signals in a 1949 Chevy 1/2 ton, I know how to wire the (6 volt) flasher, but how and where do I mount the flasher?
Thanks | | |
#93824 12/10/2005 6:50 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | DW,
This might seem crude, but I have seen the flasher, inserted in the base and hung by its wires, hidden from view behind the dashboard. A few zip ties and your all set.
Stuart | | |
#93825 12/10/2005 7:00 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Mine is zip-tied on top the column, low enough I can easily get at it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#93826 12/10/2005 10:06 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you fasten it to the column or rear of dash you can hear it click better. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#93827 12/10/2005 10:10 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | mine works better if is hanging down, no joke, it does.............Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#93828 12/11/2005 12:58 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Joker,
Darn it..stay on topic here! We're talking about flashers. :p
Stuart | | |
#93829 12/11/2005 1:11 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | tis true, when my flasher is tied up-right it will not work, if I let it hang down, it will,,, why would that be.............Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#93830 12/11/2005 3:20 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Joker, I can tell you...I have an opinion on everything, probably not right, but a opinion anyway. The flasher has a bi-metal spring in it. Two different metals are sandwiched together to make a flat little paddle. As current passes through it,the paddle heats up. Because the different sides of the sandwich expand at different rates, when it gets hot, it curls over sort of like a banana. When it "gets bent" so to speak, it pulls away from the power contact, and presto, your lights go out...paddle cools off, hits contact, light come on, paddle gets hot, pulls off contact, lights go out...over and over and over. Yours won't work because you have the "Horizontal Model"...banana will only function laying down on the job, or a loose wire! Stuart | | |
#93831 12/11/2005 3:29 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I even installed a new one and it acts the same.. as long as it is dangling, it works fine so I have left it that way... crazy deal huh, so I may have a loose wire,, will check it out,, thanks..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#93832 12/11/2005 6:31 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | My turn signal flasher just kind of hangs there, too.
Speaking of which... I forgot to pull that today when I was out there.
Darn thing finally gave up the ghost. | | |
#93833 12/11/2005 6:52 AM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | A three prong headlight connector will fit a regular flasher, in case anyone is interested. | | |
#93834 12/21/2005 11:58 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | Can you folks buy "Hella" parts in the US? They make electronic flashers (6 and 12 volt) without that bi-metal stuff.
May sound strange but this was a big improofement on the 41 with 6V system.
With the bi-metal flasher you cant hardly notice the flashing it was more like a dimming on and off and the indicator light came up only randomly..
Wit the new "Hella" flasher it blinks like a modern car, it has a loud klick (so I don`t forget it, and the little indicator lamps at the switch work fine and bright now.
Frank | | |
#93835 12/21/2005 11:59 PM | Joined: Jun 2005 Posts: 50 Member | | Member Joined: Jun 2005 Posts: 50 | Where can I buy a replacement flasher for my 6 volt sys.?
PJP
#93836 12/22/2005 3:57 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Hella makes wonderful stuff. I'm going to install their H4 headlights in both my '54 panel and '77 Corvette.
Francis - see the post right above yours. A search for "Hella" on Google should turn up any number of parts sources - try those that supply Volkswagen parts, the Beetle used a 6v electrical system well after most other cars had ditched it. | | |
#93837 12/22/2005 4:36 PM | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I had thought about letting my flasher hang down like Joker and to zip tie it to a support on the dash board.
I got a clip from NAPA that I attached to the firewall. It is just a simple compression clip that the flasher snaps into.
Works great.
Dennis -there is nothing stronger than the heart of a volunteer-
