2 members (Phak1, Bill Hanlon), 116 guests, and 1 robot.
Topics128,129
Posts1,056,360
Members48,441
#927412 03/14/2013 10:33 AM
Good Morning all
I am currently in the process of rebuilding the shift lever on my 49 chevy P/U. I have the shift lever repair kit for the 3 speed on the column. it has the pins, spring and rubber bushing. Is there a secret to how to put this back together. I am having trouble with this. Not for sure how the rubber bushing fits in this. Can someone point me in the right direction. Thanks for your help.
Bennie
Bennie,
Where did you get the kit?
Marc
Marcus, any of the vintage vendors have the kit, fits 47-59
Bennie, the rubber bushing is not part of the knuckle assembly at the wheel unless it's meant to fit on the knob on the elbow piece that fits inside the sheet metal lever, might be for the box down the column .... it is tricky to get the pins and spring in place, helps to have the whole unit off the column .... if you have an assembly manual it should be shown in section 7
ha, according to Larrys picture the rubber does go on the end of the elbow, I don't recall that being on the TF series
