| | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | today i was trying to install my bed wood on my CE . it seems like the rear is missing a wood spacer to raise the body a little. by raising the body a little i would be able to put the wood under the inside bed lip. heres a picture of where i think the spacer goes ce frame | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I believe that the suburbans use the same wood block spacer and it is available from a few vendors. | | | | | Joined: Feb 2006 Posts: 64 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 64 | Correct G, Takes the same body mount kit. I used thick rubber s/steel for the rear spots, body should be level with running boards. | | |
