7 members (dt235sd, Bill Hanlon, bnauman, Ridgeback, Otto Skorzeny, 1955 1 Series, Chris's 46 / 515),
79
Mod | | | Forums66 Topics128,175 Posts1,057,115 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | I have a 53 gmc panel with the original pedal assemblies. Clutch,brake and gas pedal. I would like to put some billet or chrome pedal assemblies in. What would you suggest and how would these work. Everything I have searched and found mounts on the firewall. Or am I just confusing myself? LOL
Any help is appreciated | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Is your truck stock or are you modifying the column, drivetrain, etc.?
If it's stock I know of no aftermarket "bling" pedals available. If you are modifying the truck , however, you have many options.
My panel now has a hanging brake pedal assembly w/ firewall mounted booster/master cylinder. Frees up a lot of room down below. I have no clutch now since it's a T400 auto. Lastly, I went with a Lokar "thru the floor" gas pedal and linkage.
mike
| | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Squire, Thanks for the info. the master cylinder is in the stock location right now and the clutch and gas pedal are stock.
I do want to modify it like you are saying with the firewall mounted booster/cylinder. | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Squire, Who would you suggest for the firewall mounted booster/cylinder? I have disc brakes front and rear and running 1 ton axles.Something that wont take up a lot of room under the hood would be nice.
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I used the entire kit sold by CPP. First, the under dash pedal bracket assembly needs to go in. THis means the existing stamped sheet metal column bracket gets cut out. The new pedal/booster mount assembly goes in with the 4 booster mounting bolts going thru the firewall. You just tell them you are doing front discs and rear drums and they include the proportioning valve and is pre-mounted on the booster/master cylinder. No clearance issues; I stuck a 455 Buick in mine and no issues. I have front discs & My rear end is a 56 Olds. I have great brakes and the pedal assembly is VERY stout. The only clearance issue inside was where the bracket bolts to the bottom of the column area. IN my case my new AutoMeter gauges were just a bit too close to the bracket; so I had to grind a small amount of material to allow for the fasteners on the gauges..... So, if you are going aftermarket gauges just trial fit before bolting everything in. Like I said, I needed to free up room underneath for exhaust/trans/trans cooler, etc. Hope this helps. | | |
