3 members (Otto Skorzeny, Shaffer's1950, 1 invisible), 164 guests, and 5 robots.
Topics128,088
Posts1,056,122
Members48,435
I'm having a hard time removing screws from (1963 gmc pickup) inside door panels. Can someone give me help on getting these screws out, thanks in advance for your help
Got Mig?
Give me ambiguity
or give me something else
i had to drill mine out
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
I had to weld nuts on some of mine to get them out
I've found the small impact drivers that use the 1/4" hex drive
are great for dissasembling these old trucks. I've used my
Makita 18v for removeing stubbern screws and bolts from inner
doors and door hinges that conventional scrwdrivers or sockets
wouldn't budge. Works great on clutch head screws also.
Try one and you will be amazed at the difference.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Between the two upper posts you have my method... I have a HF bag-o-bits and just weld a 1/4" bit (whatever fits)to the screw and then twist. Heat plus solid purchase gets most of the really bad ones.
Give me ambiguity
use a hammer drill on slow speed in reverse with the right bit for the screw
