8 members (Nick in Manitou, 51sub, TUTS 59, Bill Hanlon, 1955 1 Series, NJC, WICruiser, greenie-reddy),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 22 New Guy | | New Guy Joined: Apr 2013 Posts: 22 | Bought an engine that was pulled out of a Jeep. Owner said it's a 250 but I can't verify the numbers. The number above the starter is CON2. The number at the dipstick is B271, and the far right serial number is 473483 with a large GM cast below that and the number 10 cast below the GM. I can't find these numbers anywhere. Any help would be appreciated.
If the dash ain't steel, it ain't real!
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | All sorts of answers from a web search:
473483 is a 1975-1976 250 or 1973-1979 or 1966-1979 or 1979-1985 (integral manifold/head, supposedly)
Is the intake manifold integral with head?
Maybe someone will know of the meaning of B271 at that location on the block.
I'd guess (a wild guess) that it is a date casting code:
B = February 27 = 27th 1 = 1971 or 1981
| | | | | Joined: Apr 2013 Posts: 22 New Guy | | New Guy Joined: Apr 2013 Posts: 22 | Thanks for the info. The intake is separate from the head, which is good since I want to install a 4 barrel carb. I am also looking for some short tube headers. The engine has a smog pump which is plumbed into the head at each cylinder. I think I can remove the piping and plug the ports since I do not need the smog option. Thanks again fair the help.
