| | | Forums66 Topics128,179 Posts1,057,162 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I'm trying to find out some information on the early and later type water pumps used on 235 engines. I have a 1957 235 engine that has the water pump mounted in a hole in the front of the engine block. The engine is going in a 1953 AD 1/2 ton truck. Originally when I rebuilt the engine, I shortened the shaft on the water pump and pressed on a pulley from a 216 external water pump. I see where they say this is a no-no. It turns the water pump to fast this way. Question, what was the original size pulley used on the 1957 engine? I wondering why I couldn't machine the 216 hub and remove the pulley and add a larger diameter pulley to it.
thanks John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is common to use a 292 Ford pulley for the setup you are using.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Is your motor in an AD? Even with the shortened pump I had wondered about clearance between the fan and radiator. I had considered using a front mounted electric fan on it, but by your picture it looks like the fan will clear. John | | | | | Joined: Mar 2007 Posts: 4,216 Moderator | | Moderator Joined: Mar 2007 Posts: 4,216 | I have 1/8" between the fan and the balancer. Between the fan and rad is no more than 1/2". Perfect fit in my opinion, yes it's in my '53 panel. Engine is a '60 261. | | |
