| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | I have a 1952 chevy truck half ton, with a cover riveted over the hole for the radio. Without removing the cover, what are the measurements between the knobs and what size square hole for the radio. Does anyone have a radio deleate plate close at hand that you could measure for me. Please guys I got a once in a lifetime chance at a box type radio that looks just like the ones that install into these trucks with the speaker located front bottom of the radio to line up with the speaker grill, its a wonderbar out of a cadillac and the number on the radio is 7258865, will it fit? thanks HUGH
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The controls are close to 7 1/2" apart and the bezel on then radio is approx 2 1/4" x 5". I hope that helps. | | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | Those measurements are inline with this radio, the radio face is straight and not angled like the original. I think maybe it would tilt enough through the holes enough to mount though. Upon closer inspection with a mirror and a flashlight to the backside dash riveted area, it seems like my dash was cut sometime in its past. The 2 1/2 x 5 area still exists, but they cut the area where the knob shafts pass through. Think this radio might fit, its complete with knobs and foot dimmer switch and is suppose to be functional, and is astetically pleasing to the eye. Thank you so much for your time in measuring this for me. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You could make a faceplate that is larger than the affected area and cover it up.
What is the foot switch for, tuning? Is it a Wonderbar? | | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | yes it's a wonderbar radio, according to the guy you mount the dimmer switch lower than the stock dimmer switch, and you can use ur foot to tune the radio.And thanks for the tip for the larger plate to cover up the disturbed area. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow, that is a 49/50 Cadillac radio, according to an Ebay listing. Working Wonderbar radios are really something. Even without the automatic tuning they are a nice radio. | | | | | Joined: Nov 2012 Posts: 185 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 185 | Thats the one, think I am going to pass on it, as I have other repairs zapping my savings. I am looking at one of the am/fm radios aftermarket made just for my truck. But that will have to get inline behind other repairs, really appreciate your assistance, HUGH | | |
