7 members (78buckshot, Waveski, Steveoreno, Jay R, carbking, Ridgeback, Forty9), 70 guests, and 4 robots.
Topics128,180
Posts1,057,164
Members48,465
#937351 04/21/2013 12:06 PM
I'm trying to find out some information on the early and later type water pumps used on 235 engines. I have a 1957 235 engine that has the water pump mounted in a hole in the front of the engine block. The engine is going in a 1953 AD 1/2 ton truck.
Originally when I rebuilt the engine, I shortened the shaft on the water pump and pressed on a pulley from a 216 external water pump. I see where they say this is a no-no. It turns the water pump to fast this way.
Question, what was the original size pulley used on the 1957 engine? I wondering why I couldn't machine the 216 hub and remove the pulley and add a larger diameter pulley to it.
thanks John
It is common to use a 292 Ford pulley for the setup you are using.
My Blog
Leo Offline
Moderator
Moderator
My fan was turning too fast, had to slow it down. I simply put a 6 3/4" pulley over top of the 4" pulley. I got a slightly longer fan belt and I am as happy as can be with it.
If you look carefully, you can see both pulleys.
http://i365.photobucket.com/albums/oo91/1953panel/DSCN02251_zps529d5ab8.jpg?t=1366584373
Is your motor in an AD? Even with the shortened pump I had wondered about clearance between the fan and radiator. I had considered using a front mounted electric fan on it, but by your picture it looks like the fan will clear.
Leo Offline
Moderator
Moderator
I have 1/8" between the fan and the balancer. Between the fan and rad is no more than 1/2". Perfect fit in my opinion, yes it's in my '53 panel. Engine is a '60 261.
