| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Hey Guys, I have a question.I have a 53 gmc panel and have the little arm that attach to the top of the doors to limit how far they open. I have the holes on the top of the door where they bolt to,but cant seem to find where they bolt to on the body. I know this should be pretty simple,just want to make sure they are in the exact location. Any help is greatly appreciated.
Thanks in advance | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Alvins panel shows them but not a great picture of the location. From jim Carter You might have to expand this one to see the detail | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Thanks Gmoniz, That does help, I appreciate it | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | MNSmith's photos are of Suburban "stop arms". The panel truck doors' stop-arms have a notch in them, for part-opening and full-opening (to back up to a loading dock). links to photos in this post | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Doh! Panel! I saw "barn doors" and got all nutty! | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Thanks Guys, The pics really have helped.I do appreciate th help with this | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Manley, on my panel, if I open the doors all the way, they hit the tail lights. I had to make adjustments on the arms to prevent that. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A 47-54 panel truck with original, single tail/stop lamp in the original location should be no problem with doors full opened. Has anyone had a problem with this?
The dual tail/stop lamps in the locations designated on the installation template should be out of way of fully opened rear doors.
| | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | On the panels, the doors and door stops were designed to goto the full 180 degree in the open position without hitting the taillights. If it is hitting the lights are not mounted properly.
Do you have pictures showing the taillights and the doors open? Remember these taillights were installed by the dealer or someone else outside of the factory, they were not factory installed.
I have seen door checks installed with a bolt /nut and washer in the slot to prevent the doors from opening in the full position. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I have seen door checks installed with a bolt /nut and washer in the slot to prevent the doors from opening in the full position. That's what I did. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The rear doors on my Suburban do not come near to touching the 47-55 "bullet" dual tail/stop/signal lamps. This template was used. If you print/use this template, you can be sure you have the correct scale by measuring the 3/4" hole. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Suburban doors do not open as wide as panel doors. As George noted the panel doors were designed to open wide enough to back up to a dock. | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | Looking at MNSmith's photos, I have the suburban stop arms. Would these work on a panel?
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I would assume they are interchangeable. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | rnterchangeable yes, but they do not open 180 degrees and they fit the headliner differently. Tim posted the two styles. earlier. The panel checks are more common too. | | | | | Joined: Dec 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 64 | where would I find a pair of the panel checks/arms? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Post a Part Wanted Ad in the Stovebolt.com Swap Meet forum.
