Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (NJC, tclederman, moparguy, GRNHydra, Wayne67vert, 78buckshot), 57 guests, and 1 robot.
Topics128,009
Posts1,055,293
Members48,419
#93719 12/04/2005 3:15 PM
putting the harness together on this 49 Pickmeup, had the Gauges redone by jim carters, the ammeter has no plus or minus on it, WHAT to do? The book shows plus and minus but no marking on the Back of the gauge in the ammeter area!
#93720 12/04/2005 5:41 PM
Go by the marking on the front of the guage.
#93721 12/04/2005 6:40 PM
V
V Offline
Try it and see. You won't destroy the gauge by hooking it up backwards.
#93722 12/04/2005 6:43 PM
bodiman,
I think cletis is correct. If the front of the meter has a - and + on the front, which it should, use a marker if you need to, and put those corresponding marks on the rear posts for reference. Battery would go to + side and any load would go to the - side. smile
Stuart
#93723 12/04/2005 8:57 PM
THANKS EVERYONE, I HAD A FRIEND SAY THE SAME THING, FUNNY HOW SOMETHING LIKE THIS CAN THROW YOU OFF, THOUGHT I WAS ELECTRONICALLY EDUMACATED, BUT GUESS NOT!
STOVEBOLT COMES THRU AGAIN............
MARK!
#93724 12/05/2005 3:49 PM
Now make the gauge w/ a pen. A very important tip:
Cover those two lugs w/ a plastic cover or two layers of heat shrink. Both are HOT 12v terminals.
Jim & Caroline
#93725 12/05/2005 10:29 PM
if its backwards just reverse it.. the needle will then reverse also....the needle is kinda like a teeter totter..it goes to the side with the most potential.... its not polarity sensitve...
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
