0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 1 Moderated | | Moderated Joined: Apr 2013 Posts: 1 | i have a chevy COE 5700 series and my right rear brakes had all four return springs snap when one of the wheel cylinders burst, can anyone help me find them i've had no luck! please Help me! | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | One of the members here, His handle is 3B, found mine for me at Rockauto. Mine is a 1957 - 2 & 1/2 Ton GMC COE. It has 4 springs per wheel on the rear. The price was good too. All 8 of mine were broken when I bought it. I have yet not been able to navigtate Rockauto site, but he found them. They came all 8 in a box for 15.39 Wtih shipping only cost $26 for 8. Part # H500 NAPA # is UP80164 cost $17.10 not including shipping. Of course this info is for a 57 GMC, yours may be a different part #. But this will give you somewhere to start. P.S. They may move this topic to the driveline forum.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 54chevyCOE, welcome, a bit more information will help locate your return springs. Width of brake shoes, number of springs per wheel, are your springs all the same length, are your springs short barrel type ones, if you have enough pieces left could you estimate the length of the springs? I'll be away all day but if you can provide more info I'll work on this when I get home this evening. | | | | | Joined: Feb 2009 Posts: 400 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 400 | pull the good ones off the other side then take them to your FLAPS and measure to replace broken ones | | |
