| | | Forums66 Topics128,022 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | I found an old 3 piece oil bath (lid, element, can) however, it seams to be missing a gasket between the top of the carb neck and the can. It causes the vehicle to run rich. I have tried with varying oil levels and without oil, no change.
Any ideas? | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | And I cleaned the element in the same manner as my two piece oil bath, and dried and oiled it, no luck.
W-1 carb, 216 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My oil bath has no gasket between the carb and the base that sits on it. Near as I can tell it never did. There is a rubber seal between the base and the copper filter media canister then again between the filter media canister and the lid. I think it's more of a carb issue than a filter issue.
| | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | Mine is missing the gaskets on either side of the element. The carb sorks great with a paper or the later style air cleaner. I will see if I can recreate or track down the missing seals. | | |
