4 members (Hotrod Lincoln, Gray_Ghost, cmayna, dt235sd), 119 guests, and 0 robots.
Topics128,051
Posts1,055,732
#936712 04/18/2013 6:04 PM
Y
Y Offline
I found an old 3 piece oil bath (lid, element, can) however, it seams to be missing a gasket between the top of the carb neck and the can. It causes the vehicle to run rich. I have tried with varying oil levels and without oil, no change.
Any ideas?
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Yelostn78 #936714 04/18/2013 6:05 PM
Y
Y Offline
And I cleaned the element in the same manner as my two piece oil bath, and dried and oiled it, no luck.
W-1 carb, 216
Yelostn78 #936824 04/19/2013 8:32 AM
Ex Hall Monitor
Ex Hall Monitor
My oil bath has no gasket between the carb and the base that sits on it. Near as I can tell it never did. There is a rubber seal between the base and the copper filter media canister then again between the filter media canister and the lid. I think it's more of a carb issue than a filter issue.
Yelostn78 #936918 04/19/2013 4:51 PM
Y
Y Offline
Mine is missing the gaskets on either side of the element. The carb sorks great with a paper or the later style air cleaner. I will see if I can recreate or track down the missing seals.
