0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | the other day i went to atwoods and saw what they called "pre-52 oliver tractor medium green implement paint". looked to me like hunter green paint that would match my truck, so i took a can of hunter green rustoleum over and compared it, looks like the same color to me. but my question is, will it look stock if i paint it this color? if not how much difference in color? if it is really close (or the same) i'll get it because it's only 30 bucks a gallon compared to 50-70 a gallon for automotive paint, and it is much stronger than automotive paint and i will need a more resilient form of paint as my truck will be used almost daily. thanks again you guys, Indy
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I've heard of people using this paint for cars/trucks before. I would also get the hardener that they make for it. makes it more durable. The paint is basically enamel paint. What brand do they sell? They use to sell Vaspar at Tractor Supply, but now sell Majic (sp?). Which is the same thing, just a different brand..... John | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | t it's only 30 bucks a gallon compared to 50-70 a gallon for automotive paint, and it is much stronger than automotive paint... Ummm REAL automotive paint runs closer to 200 to 1200 dollars a gal... But, I'm sure you just get extra boogers and sawdust for the extra bucks... Which explains why 30 dollars a gal acrylic enamal is so much tougher. It's Pure....... BS.
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Whitelightning, I have restored many 2 cyl John Deeres over the years, and always use thier Classic Green to insure the correct color for the period. This is practically the same paint you are talking about. Just a little higher at Deere: $50 to $60 gal. It is a Synthetic Enamel and you must use syn. reducer and syn. hardner (cheap) You won't need much reducer, sometimes none, the less the better. Put it on as heavy as possible without runs, and you will have a great, durable shine.(don't forget the hardner). One gallon of green will cover a tractor with about 3 coats. Look at the Deere in my Phobucket link.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Ahhhh. The John Deere "putt-putts". Those tractors were surprising at how well they would do in tractor pulls back in the day. Seems like they were hardly working up a sweat.... haven't heard any of them running around the country side for years now. I guess most of them have been retired to tractor shows now.
John | | | | | Joined: Apr 2013 Posts: 33 New Guy | | New Guy Joined: Apr 2013 Posts: 33 | I've sprayed my share of John Deere implement paint and I fully agree with Old GMC. Use the hardener and with a good prep job it will shine as well as anything else. It is a synthetic enamel and is 1950's paint technology and might not stand up to long term outdoor use as well as a urethane would. I'm not sure I agree with the statement of implement paint being tougher. It's usually the first to start oxidizing. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | t it's only 30 bucks a gallon compared to 50-70 a gallon for automotive paint, and it is much stronger than automotive paint... Ummm REAL automotive paint runs closer to 200 to 1200 dollars a gal... But, I'm sure you just get extra boogers and sawdust for the extra bucks... Which explains why 30 dollars a gal acrylic enamal is so much tougher. It's Pure....... BS. Real automotive paint runs $80-$100 a gallon around here for a standard color, maybe a little more for a custom color.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Prices on paint vary according to what type your buying and also color. Synthetic enamel would probably be the cheapest, but less durable, then acrylic paint, then you get into your urethanes and basecoat/clearcoat paints...... Reds and blues seem more expensive than greens or yellows ect...
John | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i used "XO RUST" hunter green oil enamel on my dump. the guy at the hardware store said it was better than rusto paint. $25 a gal. painted it four years ago and still looks good and is holding well except for wear and tear. once a year i wax it with mcguires spray and wipe wax and when im done it looks as though it was just painted. dries to touch much quicker the rusto. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | I've heard of people using this paint for cars/trucks before. I would also get the hardener that they make for it. makes it more durable. The paint is basically enamel paint. What brand do they sell? They use to sell Vaspar at Tractor Supply, but now sell Majic (sp?). Which is the same thing, just a different brand..... John i can't remember what brand , but is medium green the same as hunter green?
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Yep, the 2 cyl. Deere putt putts are about out of use now and put into collections. I do have a neighbor near my shop that still uses one on occasion. I hear it start up every few days. I still have one that I use around the place. Back to the paint, correct: the Syn. Enamel will fade out in the sun over time. The hardner helps some and a yearly waxing. I have seen some green John Deeres turn blue!
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | THAT WAS THE BRAND!!!!!!!!! i could not for the life of me remember what brand it was, thanks whitedog
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Apr 2013 Posts: 33 New Guy | | New Guy Joined: Apr 2013 Posts: 33 | My own personal experience with Van Sickle isn't good. It's probably ok if you're painting a brush hog or a gate but unthinkable to use on anything you really care about. Especially a good truck. I think it's the worst paint out there. Even the cheap DuPont Nason fleet and implement available at O'Rielly's is much much better. My opinion anyway. | | |
