3 members (cmayna, TUTS 59, 1 invisible),
146
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 13 New Guy | | New Guy Joined: Apr 2010 Posts: 13 | I'm having a hard time removing screws from (1963 gmc pickup) inside door panels. Can someone give me help on getting these screws out, thanks in advance for your help | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 |
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I had to weld nuts on some of mine to get them out | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I had to weld nuts on some of mine to get them out | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I've found the small impact drivers that use the 1/4" hex drive are great for dissasembling these old trucks. I've used my Makita 18v for removeing stubbern screws and bolts from inner doors and door hinges that conventional scrwdrivers or sockets wouldn't budge. Works great on clutch head screws also. Try one and you will be amazed at the difference. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Between the two upper posts you have my method... I have a HF bag-o-bits and just weld a 1/4" bit (whatever fits)to the screw and then twist. Heat plus solid purchase gets most of the really bad ones.
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | use a hammer drill on slow speed in reverse with the right bit for the screw | | |
