3 members (klhansen, MRMEROTH11, 52Carl), 113 guests, and 1 robot.
Topics128,052
Posts1,055,771
#93669 12/01/2005 1:05 AM
what is the difference between the pertronix system vs the mallory, my mallory is pointless and no condenser, so what is the pertronix that I hear a lot about................thanks..Fred
Redryder pix
My Hotrod
#93670 12/01/2005 2:39 AM
Fred,
The Pertronix is pointless too. grin wink grin
Stuart
#93671 12/01/2005 3:01 AM
grin
Redryder pix
My Hotrod
#93672 12/09/2005 12:47 AM
the 63 continental i had was using a mallory points eliminator thing
the gritty details i don't know, and i'm not the one that did the install, but i think the mallory used an optic trigger whereas the pertronix is magnetic.
#93673 12/09/2005 2:11 AM
Joker, you put the pertronix on a standard distributor and it replaces the points and other bits inside. It has a spining magnet and a pickup coil/brain thingy that fits entirely in the distributor. So it still looks stock, other than an extra wire coming out of the distributor (if you care).
#93674 12/09/2005 2:25 AM
I put a pertronix in my 54 235..All I did was take the cap off, removed rotor, removed condenser and points, replaced small screw in point plate, put in unit and replaced rotor..Wire from Pertronix goes to the coil..Started it up.
Steve
#93675 12/11/2005 8:21 PM
The Mallory Unilite has a MUCH hotter spark than the standard pertronix ignitor.
Jason
#93676 12/11/2005 10:01 PM
Thanks,,,Fred
Redryder pix
My Hotrod
#93677 12/13/2005 5:33 AM
Joker...I can't speak to the Mallory, but I've had the Pertronix in my '65 305E V6 for 4 years with not even a hint of trouble. Install was as easy as described above. 'Course, I'm keeping the old points just in case it fries someday, but I have faith in it.
Scott
1964 GMC 1002 Long Wideside w/305E V6 & sm420 "Blue Jeans"
1996 Harley Davidson FLHTCI
1981 Husky 250CR
http://community.webshots.com/user/gmc1002hf5669a
#93678 03/01/2006 9:54 PM
bump,,,,, for Ed miller
Redryder pix
My Hotrod
joker #897832 11/19/2012 11:53 AM
Bringing an old post to life! Getting ready to purchase a pertronix kit for the 305 in my 67, original motor blew so the PO replaced it with a 305D if that makes a difference. A friend of mine is willing to offer me his 91162A Ignitor 2 for cheap if it works for my application.
Thank you in advance for any help you have to offer
Luke J McCain
