| | | Forums66 Topics128,164 Posts1,056,965 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 2 New Guy | | New Guy Joined: Apr 2013 Posts: 2 | Does anyone have a TCI chassis in the 47-54 model. I was wondering because i recently had ordered and put mine together and now it is coming down to picking out wheels for it. I know the width i want is about 10.5" wide by 20" rims in the back. I have extended rear fenders in the back so i can fit wider tires and give it that street rod look. So i guess my question is " What backspace and offset would i need for my wheels?" From the front of the rotor on the rear to the frame is about 5 3/4". I have never really had to order wheels without a set of originals in front of me before | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | You best bet is to get under there with a measuring tape and straight edge with the truck at ride height and the box on to figure out your backspace to get the look you want. I always want to get the wheel as far out as possible to make the fenderwell look full, but the look you're after will affect your backspace. Also have a look at what wheels you want and what the standard backspace is on wheels of that size and style.
I have 15x10" wheels with 3-3/4" backspacing on the back of my '46, but that's also with stock fenders and an S-10 rear end, and the box is tubbed.
