1 members (dt235sd),
141
Mod | | | Forums66 Topics128,260 Posts1,058,319 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 3 New Guy | | New Guy Joined: Apr 2013 Posts: 3 | I just got a 1958 chevy 3800 apache wrecker Im planning on restoring it. The Truck is missing the master cylinder and the brake linkage from the brake pedal to the master cylinder. If anyone can tell me where to look for the parts it would be appreciated! The wrecker is a Holmes 6000lb CAT# 460 sn RC5-2010 model# is blank on the data tag. If anyone can tell me anything about it or where I can find information it thanks. Thanks for reading Herman | | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | Hi Herman and welcome to Stovebolt.com! We have a couple of Holmes experts on the site. Search up a user named "Spanky" and send him a private message and he will most likely give you an education on Holmes wreckers.
For your brake parts, trying placing a wnated ad in our swap meet -- I bet someone will have those parts for you.
Good luck with your truck!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2013 Posts: 3 New Guy | | New Guy Joined: Apr 2013 Posts: 3 | Thanks you John Milliman I appreciate the help !! | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | I'm not sure exactly which part of the brake linkage you are missing. The "pivot point" for the brake pedal is integral to the master cylinder, i.e. the brake pedal arm attaches directly to the master cylinder. Hope this helps.
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | American Classic Truck Parts has the master cylinder,92.50.Tell them you belong to Stovebolt.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
