| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | I'm wondering if the front axle on a 41' GMC COE is weldable? I'm not confident enough to tell with the testing methods on my own. The reason I'm asking is I've been thinking of making a drop axle for it to get it a little lower to the ground. I've also been thinking about removing a couple of springs from the spring pack to soften the ride a little. It's a 4/6 ton truck so it has plenty of leafs to be safe and an overload pack if I haul anything heavy. I'll never haul that much, just want to get a better ride. What are the opinions on this? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Welding something like an axle should only be done by a very qualified and experienced welder. Even then, do you want to trust that the only thing keeping you on the road is welded together with a hope that it will be fine?
I am a metallurgist and deal with welding quite a bit. I know welding of axles has been done lots, but as one of the most important components on your truck any welding and re-engineering should be done extremely carefully. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have never understood how they stretch these axles by heating them considering they are a forged part. I though that was a no-no. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Since you are a metallurgist, can you tell me if it's cast steel or cast iron? I can weld just fine, just not as confident in knowing between the two. I welded my steering arms on my Fj40 and they work,welded the a-arms on a circle track car and haven't had any probs, welded spring perches on a semi at work??? Not trying to be cocky just want to know if it can be done? If it's steel, I can weld it. This thing only goes 45mph. I could skid it to a stop with the axle dragging, it'd probably work better than the brakes. LOL. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I'm not sure what these axles were made from in 41. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | I know there's a chip/curl test that can be done, I'll need to find someone thats confident enough to do it. Hopefully I can get enough out of the springs to save me the trouble. Thanks for the replies. | | |
