3 members (Hotrod Lincoln, 1955 1 Series, tricordati), 157 guests, and 5 robots.
Topics128,095
Posts1,056,480
Members48,444
I have a '56 chevy 2 ton flatbed truck that I want to rewire. The harness does not have to be 100% show correct but I do want an excellent quality of materials. I want to have a fuse panel and enough extra circuits for a decent stereo and A/C to be added as well as a couple of other accessories. I want the harness to look right going into the firewall and the plugs/terminals to have that well finished look(not hand crimped with generic terminal ends). Does anyone have any recommendations for a quality harness? Has anyone had a good experience using a companies harness products?
Thanks for any advice.
David
I've used wiring from 3 different suppliers - all were fine, and the correct factory configuration, for either generator or alternator -
you'll find folks to recommend every make, so you're best to just use a dealer you like and trust! remember Jim Carter [your area] has a 20% off sale right now grin
"extra circuits" just means a few more spots on the fuse panel, and the original fuse panel [not always installed, but available from most repro places] has about 3 'ACC' fuse spots that should do ya, don't need to order the very expensive packages some sell for all the street rod bling that you'll not likely use
Thanks again Bill, I hav'nt ordered a lot of things from suppliers yet. I have been getting up used and NOS parts as funds allow.
David
try PAINLESS WIRING solutions. they make several different types of harnesses
I'll do a search for them on google. Thanks koolbar.
