| | | Forums66 Topics128,003 Posts1,055,243 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | I'm new to the hobby....so going to all of the experienced folks on Stovebolt for inpu/advice. I went to install new front bumper on my 54'....and wow....is it turning into an ordeal to get to fit all the bumper bolts.
I can tell from the old bumper that it too was a challenge by the way the bolts were orientated. Is there some good tips on best way to fit? Right now I have all bolts in with the exception of the 2nd bolt from the right...and it's way off.
Also, the trim piece between bumper and grill is fiberglass(!)....and is broken....that had to have been steel from factory, correct?
Thanks in advance!
1954 Chevy 3100 (3 window/4sp) 1966 Ford Mustang convertible (Factory K-code) See...Ford & Chevy can get along after all!
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Must have had an accident at some point and brackets are bent out of shape. Get/borrow a pair to compare.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | That's what I thought as well....and did fit new repro brackets with same result. Given age of truck.....it's entirely possible an accident happened at some point and that's what's making it so difficult.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You are correct on the front gravel panel they are all steel. When you fit it up did you leave the bolts loose or tighten as you go? They are all off a bit when going from old to new. When you say far out, how much are we talking about? If all make but one try fitting that one first and then the rest leaving them loose, mine required a bit of work, you can also loosen the attachment bolts to the frame, make them all then tighten everything up. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Good mention on leaving the bolts loose where the brackets meet the frame, some times it takes that to get all the bolts in and started in the spring steel bumper. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | You are correct on the front gravel panel they are all steel. When you fit it up did you leave the bolts loose or tighten as you go? They are all off a bit when going from old to new. When you say far out, how much are we talking about? If all make but one try fitting that one first and then the rest leaving them loose, mine required a bit of work, you can also loosen the attachment bolts to the frame, make them all then tighten everything up. Thanks for confirming the front panel was steel from factory. Am I mistaken that you can by replacements in steel or fiberglass? I don't want fiberglass, but thought I saw it listed in classic auto parts catalog. I'm going back out today after a good night sleep and try again. I'm hoping some combination of bolt loosening at frame and bumper will get it done. I'd say the bumper bracket is approx 1 inch to the right of the bumper hole. With most of the other bolts...while in place....are not straight in. Oh, silly question....what's with bumper hole straight on with nothing to go into. Doesn't fit bumper bracket or gravel panel...at least not the one I removed. Thanks!
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | The original front pan had a center "L" bracket that the the center bumper bolt went through. A least on the AD trucks it did. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Steel reproduction front panels are available. Do you have the bumper brackets inside the frame or outside the frame. Might you have them on up-side-down? The vestigial bumper hole. | | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | Steel reproduction front panels are available. Do you have the bumper brackets inside the frame or outside the frame. Might you have them on up-side-down? The vestigial bumper hole.I have the brackets outside the frame with the manufactured bump fitting into corresponding indent on frame. Is that correct? Thanks for the link on the info on middle hole of the bumper. I have so much to learn about these incredible machines. I'm thankful for the people at the Bolt willing to share their wisdom. Kevin
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You will find that one inch out to be make able with everything loose. I had a couple with that kind of distance, it fits and now it pops right on and off without much trouble. I have found that when fitting parts to the trucks with multiple attachment points like grill, fenders, bumpers, window trim, etc. getting everything started and left loose often does the trick. Good luck! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I used the method Brad described.
One thing I did do was used some longer bolts from the hardware store, started with the long bolts where the bracket attaches to the frame with the nut just started. This gave me more play on the brackets.
Then started on the bumper bolts also using longer bolts.
Once I got a nut on everything I started to draw it in evenly
I aslo had to use a tie down ratchet strap on the bracket to get the last hole lined up and the bolt started.
Once everything was snug I changed the long bolts out for the supplied button head bumper bolts one for one.
Good Luck | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Bumper brackets are made of mild steel not spring steel. They can be bent or should I say straightened quite easily by clamping a bar to the bracket for leverage and bending it to where you want it. All of the bumper brackets that I've installed, front's and rears, new or old on my '50 and my '54 needed to be adjusted a bit to get the holes to line up properly.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2013 Posts: 23 New Guy | | New Guy Joined: Mar 2013 Posts: 23 | Bumper brackets are made of mild steel not spring steel. They can be bent or should I say straightened quite easily by clamping a bar to the bracket for leverage and bending it to where you want it. All of the bumper brackets that I've installed, front's and rears, new or old on my '50 and my '54 needed to be adjusted a bit to get the holes to line up properly.
Denny Graham Sandwich, IL Thanks, Denny. I plan on tackling next weekend....ended up scratching a few less "irritating" to do's from my list...haha!
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Wow! My truck fought me tooth and nail on just about everything, but for some reason the bumpers and bumper brackets went on easily. I feel blessed. Good luck, 66kcode! | | |
