5 members (52Carl, dt235sd, Otto Skorzeny, Mike B, Leo), 83 guests, and 2 robots.
Topics128,155
Posts1,056,868
Members48,456
is it ok to use rubber line for vac advance?
old metal line is no good, new one is back ordered
any pros and cons
3B Offline
Hy atownkustom, yes you can use a rubber line as long as it is strong enough not to collapse under vacuum, hope that helps.
In a nutshell no in my opinion. Rubber is ok in small diameter for short lengths of a few inches or so. 20" of vacuum will suck small diameter hose shut eventually especially next to a heat source. There is a good reason why this line was steel in the first place.
Steve]
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
that line is most always rubber nowadays, easier to crimp or plug when setting timing that way
As Bill said the later ones are rubber, and vacuum lines to wipers have always been rubber. Get vacuum hose, and you will be ok.
good points ,thanks
will run rubber vacuum rated for now ,and hope the back ordered metal line shows up. I like the clean look of the metal line
you all feel the same about fuel line ? pump to carb metal or rubber
Riding in the Passing Lane
I agree on the vacuum line but fuel is different. Steel tube is safer.
1972 Chevy c10 Cheyenne Super
Is it possible to fabricate your own steel lines? Using the old one for a pattern.
1939 Chevrolet Stake Truck
Yes. Use steel brake line.
Bill Burmeister
yes how could I forget that
got it done for under $10
the one I had ordered was $25 plus shipping so thanks again
Steve]
Iagree, plus steel lasts longer
I always use a steel line (stainless) from the carburetor to the vacuum advance mechanism on the carburetor. Even though this line is well-above any of the hottest parts of the engine. Steel is safer, and it is easier to safely route around the top of the valve cover.
However, I am confused (amused?) by all the dire warnings about rubber hoses (of any length) being "sucked shut". How many of us have long-lengths of rubber hoses going from the intake manifold to a vacuum wiper-motor (this is the same amount of vacuum as in the advance line - 19"-21" of vacuum)? red58 and crenwelge (and others who posted that rubber would be OK) are, of course, correct.
Steel does last longer, and stainless steel would even last longerer.
Plus stainless steel doesn't corrode as bad as straight steel does,also I have bent it so the fuel filter can be directed as far away from heat as possible. Pat
1966 Chevy C 30 1 ton truck
