10 members (jupitor, treegrower, Lightholder's Dad, GMCJammer51, J Lucas, JW51, Tinker5, TUTS 59, wilbur53, 3B), 216 guests, and 1 robot.
Topics128,080
Posts1,055,952
Members48,430
question - how new of a model 4 speed open drive shaft transmission will bolt up behind a 1952 248 gmc engine ? redoing drive shaft would be no problem. looking to upgrade using original bellhousing thanks texman
1940 GMC AC 302 1 1/2-Ton Dually
BOHEMIATH
More pix in Flickr
3B Online: Content
3 Online: Content
Hy texman, if you want a four speed with a p.t.o. opening and capable of some work, then the SM420 would be a good choice. If you want something with overdrive in a light duty truck, then a T5 may be more what you're looking for. The T5 takes some adapting, the SM420 is a bolt in, hope that helps.
I would rather go with something that would bolt up to what I have now . what 's the newest year model SM 420 whats trans that that would bolt up ? Texman
BOHEMIATH
More pix in Flickr
J M Offline
Texman
I believe that 1967 was the last year that the SM 420 was used in the light trucks. It is a great transmission if you aren't looking for an overdrive to get more speed.
Good luck
Jim
Crusing in the Passing Lane
SM-465 started in '68, comes in different retainer and input shaft sizes, lots of them out there, NP-540,1,2 5 speed(OD rare, gap in ratios) works well if loads to pull.
thanks a lot guys ! texman
BOHEMIATH
More pix in Flickr
