| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | SM-465 started in '68, comes in different retainer and input shaft sizes, lots of them out there, NP-540,1,2 5 speed(OD rare, gap in ratios) works well if loads to pull.
