2 members (mick53, J Lucas),
133
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I stripped the cab to bare metal,primed it and done the body work,and primed it heavy.I blocked it down thinking it would be ready for paint,and found several more small dings.I have been using Icing to work them out,but this sanding is getting old.When I was younger I did a lot of body work on the side to make extra money,but I don"t remember this much sanding,maybe thats why I stopped doing it.I will soon be done, whether I have all the dents out or not. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I feel your pain. I spent about 4 weeks doing all the prep for my bed. Finally sprayed the color and I missed a dent. Ahhhhhhhhh. This weekend is sand the finish down to 2000 and buff it. I still have all the fenders,doors, hood. Well this is fun right!
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | the body work is definitely the most challenging part of the job. I'm not even close to paint.I just have to keep telling my self how cool it will be when it is done.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I am hoping the doors and hood will not have so many dings.the cab looks like hail damage on it.I don't think it is.its just years being used as a truck.I sure am ready to move on to the doors. | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | The buffing is not much fun ether, but at least the compounds are better now so it goes better. I have repainted so I didn't have to buff. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | So who's hand sanding and who's using a DA?
I find on the 58 that the doors and hood are the only surface I can use a sander on and only part of them. I will say I find 2 softblocks laying side by side in 1/2 a sheet of paper make a better pass than a single one when your trying to cut the peel flat...
| | | | | Joined: Dec 2010 Posts: 115 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 115 | I too feel your pain. I took a break from the cab to do a door, I guess I just needed to feel like some progress was being made I put the final coat of primer on the passenger door yesterday , it's now ready for the final sanding and color. Back to cab for a while.
This is a hobby for me so I am not methodical in what I work on today. I keep it interesting and fun. When its not fun I take a break for a couple days
Kenny Martin Talladega, Ala Second place is the first loser - Ricky Bobby 1956 Chevy 1/2 Ton | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | If you guys make them to nice, you'll be afraid to drive it.... LOL John | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I use a DA some and a line sander but the cab is mostly done by hand.To many curves | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If it helps, just think of paying a shop $ 50.00 / Hr. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I use a DA some and a line sander but the cab is mostly done by hand.To many curves Speaking of curves. Does any one else make their own sanding blocks to conform to the curves they're working on? I found it really helps get them straight. I made some from hardwood but then found 2" foam board works just as well and is a lot easier to form.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've found the rubbery rollers from wringer washers work well for some shapes - for odd places I shoot some of the spray can insulating foam onto a piece of saran wrap and form it to suit and let it cure, can also shoot a light cardboard tube full [like TP or paper towel cores] then later peel the cardboard off
Bill | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Great thread, I have this to look forward to. Just think a good paint job with good body work costs a ton of money these days. If you have more time than money, like me, it is time well spent. IMHO. The last job we used feather fill and it was so much better to sand, almost enjoyable, almost. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | A few years back, Woody (I think) posted information on this Wagner Paint Eater. It works great and does not clog. This was not available when I bought the Wagner unit. I'd have no problem buying it from Harbor Freight. Buy it when you are going to use it - if it lasts 90 days of heavy use, it will last longer (if it breaks, bring it back for a refund). | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I use apoxciy primer [I can't spell] It goes on heavy and seals the body work.I think the cab is finally ready for final sanding and paint.The doors are next; | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | I bailed on doing my bodywork, a local shop a few years ago was needing some work so for $2500 They did all the body work & painted everything in pieces. They had it about a month before I started hauling it all home to put together. Between lack of time & lack of knowledge on bodywork it was the best route for me on the 1953, but I think I will tackle the next one all one my own..... | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | It's a Zen thing. You have to put on some good music (and a good mask) and get in a sanding groove. | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | When I work in the garage that is the 1st rule.The radio gets turned on before I do anything.I sanded a door to bare metal tonight,It is in good shape so it should be and easy fix.Just a few small dings.I hope the other one is this good. | | |
