| | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Not sure why these extra holes are here on my replacement outer cowl. Left and Right have 2 extra pair of holes close together and there is also a larger single hole on the driver(left)side Are they for mirrors and antenna? They may need to be filled if all I want is the top air vent and wipers. They don't even match location of stock 5in round mirrors. Anybody have any ideas? http://s1235.photobucket.com/user/kvandatta/media/1952%20Chev%20Truck%20Cowl/MirrorLeftCowl.jpg.html
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | The top large hole is probably for the radio antenna. The other 2 on each side I'm not sure, probably as you say for the mirror brackets to bolt to. John | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | I had the same questions about the paired small holes on my replacement upper cowl panel. They don't line up with any factory mirror I have ever seen.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Yeah the 2 holes on my original panel are one above the other. I think the mirror bracket was original on it.....
John | | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Thanks for confirming no easy fix on these oddball holes. They are to close to the hood when opened to be usefull when mounting stock mirrors. It looks like more bodywork and painting is in my future.
52 1/2Ton 235 | | |
