| | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 6 New Guy | | New Guy Joined: Mar 2013 Posts: 6 | My clutch, pressure plate, throwout bearing, and flywheel are all brand new ad my clutch will not engage any help will be appreciated
Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what year and configuration? do you really mean it will "not engage" or it will not DIS-engage? can you push the pedal down? does the truck try to move when you crank it with the pedal down? are you sure you used all the correct parts for your application? examine your work carefully to see what you've installed incorrectly, maybe you put the throwout bearing in backwards - you need to elaborate on the problem
Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | might have installed back wards. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Might have the wrong throw out bearing, Diaphram type pressure plate takes the long one and the finger type takes the short one, mix them up and you will have a ton of free travel or no clutch.
You Learn more Listening than Talking
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | let's see what it is first and see if we can narrow it down ron | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I agree with Joker. Clutch was installed backwards. Take it apart and redo. | | |
