2 members (PAUL Berardi, 78buckshot), 175 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#934422 04/09/2013 9:44 PM
Does anyone know of replacement patch panels for the quarters and roof rear corners for a 55 second Panel?
unfortunately there are no ready made patches for the Task Force panel/burb bodies, you're looking at fabbing up patches yourself - you might browse a bit in this forum and find a number of threads concerning the quarters, which are commonly a problem
This should show a sample of how to tackle roof issues.. I know, its not a burb, but process should be similar.
http://www.trifive.com/forums/showpost.php?p=345023&postcount=32
http://www.trifive.com/forums/showpost.php?p=347329&postcount=35
judging by those pictures you have your work cut out with that roof - in my experience you have rot similar to that shown in Roberts pics behind the rain gutter, potentially the full length of both sides depending how long it sat in the bush - the rot in the quarters could be full length too
Sir Searchalot
Sir Searchalot
Very glad you are saving it. these are rare. It may take awhile but you will find a donor panel/burb or decide to sheet metal repair. It's possible to trim the whole length with rail included about 2" up and make strips in that shape to re weld in. The rail may be made from tubing that is split? "1/4 round" sort of. Robert's link is good stuff, probably lots more on web..
Does anyone know if the bead along the bottom from rocker panel to wheel well is the same geometry as a rocker panel?
Sir Searchalot
Sir Searchalot
Yes , same. You can use the rocker repair panels for that area or shape some sheet metal.
Thank you very much!!
the rocker is the easy part, the molded edge around the wheel well is what'll give you fits, and where it tapers to nothing at the back frown
Sir Searchalot
Sir Searchalot
From the pics looks like your over the wheel is good? If so, you are lucky.
