| | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 12 New Guy | | New Guy Joined: Apr 2013 Posts: 12 | Does anyone know of replacement patch panels for the quarters and roof rear corners for a 55 second Panel? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | unfortunately there are no ready made patches for the Task Force panel/burb bodies, you're looking at fabbing up patches yourself - you might browse a bit in this forum and find a number of threads concerning the quarters, which are commonly a problem Bill | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | | | | | | Joined: Apr 2013 Posts: 12 New Guy | | New Guy Joined: Apr 2013 Posts: 12 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | judging by those pictures you have your work cut out with that roof - in my experience you have rot similar to that shown in Roberts pics behind the rain gutter, potentially the full length of both sides depending how long it sat in the bush - the rot in the quarters could be full length too
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Very glad you are saving it. these are rare. It may take awhile but you will find a donor panel/burb or decide to sheet metal repair. It's possible to trim the whole length with rail included about 2" up and make strips in that shape to re weld in. The rail may be made from tubing that is split? "1/4 round" sort of. Robert's link is good stuff, probably lots more on web..
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2013 Posts: 12 New Guy | | New Guy Joined: Apr 2013 Posts: 12 | Does anyone know if the bead along the bottom from rocker panel to wheel well is the same geometry as a rocker panel? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes , same. You can use the rocker repair panels for that area or shape some sheet metal.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2013 Posts: 12 New Guy | | New Guy Joined: Apr 2013 Posts: 12 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the rocker is the easy part, the molded edge around the wheel well is what'll give you fits, and where it tapers to nothing at the back  Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | From the pics looks like your over the wheel is good? If so, you are lucky.
