7 members (52Carl, Goach2, Hotrod Lincoln, Oswald, Hugh63c10, TUTS 59, cmayna),
140
Mod | | | Forums66 Topics128,204 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | As usual, the 3-on-the-tree shifter linkage on my '69 C-10 is jacked up. I had brass bushings custom manufactured for the linkage-to-transmission connection. Now I want to replace the grommets in the shifter-to-linkage connection on the top side. The original grommets fell to dust in my hand when I disconnected that.
Does anyone know if the specific grommets can be found any where? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | skip the hard rubber ones, get some bronze hinge pin bushings from the 'Help' rack [#38374], like the ones you had custom made, might need slight reaming but should fit and will last
Bill | | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | I like that idea, Bill. Thanks! | | |
