2 members (Nick in Manitou, 1 invisible), 304 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,460
As usual, the 3-on-the-tree shifter linkage on my '69 C-10 is jacked up. I had brass bushings custom manufactured for the linkage-to-transmission connection. Now I want to replace the grommets in the shifter-to-linkage connection on the top side. The original grommets fell to dust in my hand when I disconnected that.
Does anyone know if the specific grommets can be found any where?
Darren
1969 Chevy C-10 Fleetside
skip the hard rubber ones, get some bronze hinge pin bushings from the 'Help' rack [#38374], like the ones you had custom made, might need slight reaming but should fit and will last
I like that idea, Bill. Thanks!
Darren
