8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible), 181 guests, and 2 robots.
Topics128,086
Posts1,056,094
Members48,434
#934290 04/09/2013 2:20 PM
My clutch, pressure plate, throwout bearing, and flywheel are all brand new ad my clutch will not engage any help will be appreciated
what year and configuration? do you really mean it will "not engage" or it will not DIS-engage? can you push the pedal down? does the truck try to move when you crank it with the pedal down? are you sure you used all the correct parts for your application? examine your work carefully to see what you've installed incorrectly, maybe you put the throwout bearing in backwards - you need to elaborate on the problem
might have installed back wards.
Redryder pix
My Hotrod
Might have the wrong throw out bearing, Diaphram type pressure plate takes the long one and the finger type takes the short one, mix them up and you will have a ton of free travel or no clutch.
You Learn more Listening than Talking
let's see what it is first and see if we can narrow it down
ron
Connor #935034 04/12/2013 12:35 AM
I agree with Joker. Clutch was installed backwards. Take it apart and redo.
