0 members (), 140 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
Finally bought one. Casting #328578, F1210XTA code. '73 or '83. +0.030 with crosshatching and no ridge, and the head's been redone. I gave $375 with the clutch, bellhousing, starter, saginaw three speed, and a junk 250 for parts, for those that are curious. More than I really wanted to pay, but 292's are pretty unusual and it looked pretty promising so I went for it.
It had ran really rich before, and the PO bent pushrods lifting it, so I decided to tear it down and freshen it up. Good thing I did, rings were still good but it ate three cam lobes and lifters, and the cam bearings were beat to hell (ham-fisted install). Also the other bearings didn't seem to like the metal going through them and needed to be replaced. The -0.020 journals were still good, though.
-But, here's the really interesting part. I took off the oil pan and found a thirteenth pushrod! Didn't even match the others. I also found a spare crank key and part of the crank gear that someone had broken off. And while not a functional problem, the crank counterweights had been beaten with a hammer and deformed. It also has some casting "tumors", for lack of a better word, in the main webbing, really unusual. Also the crank key looked like it had rolled in the keyway somewhat.
And, as always, pictures
Don't ya love "rebuilt" engines you didn't put together?
Some of my crap:
1963 C-30 flatbed dually 292/SM420
1965 C-10 LWB fleet 250/column shift 3 speed
1965 C-30 9' stepside 250/SM420/4.10 gears (my DD)
Website I made for my crap:
http://www.66submarine.com
Interesting concept. I've got spare parts scattered all over my shop. It never occurred to me that I could store them in the oil pan. But since I've got several engines sitting around I'm afraid I'll forget which one I put them in. I suspect that you're not through finding surprises with this one. Maybe you'll find some gold coins if you scrape around in the sludge. Good luck with it.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
we took a diesel engine apart one time had a wire brush in the oil pan, had a ratchet in a refrigerant compressor crankcase once. It is a quite poplar place to store tools apparently.
