| | | Forums66 Topics128,160 Posts1,057,054 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | My old 3 hp Sears compresser is blow air the air out of what i guess is the intake it blew the filter out ..i took the cover off and there was a reed valve loose fixed that but still blows the air out the intake,broken ring ? any take on this .  | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If the rings were bad, it wouldn't blowing any air at all. Reed valves can be slightly bent and not work. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | Sometimes you can flip a reed valve over and it will seal better? | | |
