1 members (68ironhead), 215 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#934493 04/10/2013 2:22 AM
I have a 46 gmc one ton and would like to remove the doors to repair the rust thru. Do you just remove the large phillips screws or does the hinge have pins you can pull?
Give me ambiguity
or give me something else
The 46 is different from the AD as far as door removal goes. I believe you do have removable pins if that is the way you want to do it. I use that a lot on my 38 Master when I am working on the door itself. Removing the pins means the door doesn't have to be adjusted every time it is mounted.
If the pins are really tight, I use the ball joint/U joint clamp. I use a small bolt on the bottom of the pin and a socket to fit over the head at the top.
1951 1 Ton Completed
