| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | In the February 2013 issue of Skinned Knuckles, there was an article about a new type of carburetor needle valve. I'm getting ready to rebuild the Rochester carb on my 216, and I want to order a rebuild kit from that company, but I can't find my copy of the magazine. I was thinking I would have to buy a back issue of the magazine, but then I realized that this is a perfect use of the Stovebolt Forum. Does anyone have a copy of the article? If so, could you give me the company info?
My dad always told me, "Don't force it, get a bigger hammer".
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My mailings come in three month increments because I live in Canada. I will check to see if I have it yet. However, if you are a subscriber, you should be able to read it online. | | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | I just called the publisher, and you can't read the magazine online.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Which article is the information in? I have it online now.
It may be that international subscribers can read it online.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | OK, I found it for you. The information is in the March issue under "Unusual Products" and the company name is the Daytona Parts Company. It seems that the valve seat is named after their company. | | | | | Joined: May 2003 Posts: 183 'Bolter | | 'Bolter Joined: May 2003 Posts: 183 | Great! Thanks a lot. The Stovebolters come through again.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't see a kit for a Carter W-1 at their site. The pump has always been a problem when used with alcohol.
DG
Denny G Sandwich, IL
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It seems the aftermarket gave up on the W-1 carb. The only way ive been able to get a kit for one is through the specialty supliers. There have been a lot of different configurations of needle & seats through the years but the tapered needle seams to be the old standby. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Nothing new about the valve in question. It appears to be the old Parker Brothers valve from many years ago. http://www.thecarburetorshop.com/Fuel_valves.htmAs to the FLAPS aftermarket repair kits: There are currently 3 manufacturers (of which I am aware) that produce the aftermarket kits. Regardless of what name is on the box, the inner kit comes from one of these three. I don't know much about one (don't like their parts), but the other two have a rough guideline that if they do not sell 1000 of any given kit in a year, they obsolete the kit. Speciality carburetor kit manufacturers do not have such criteria. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
