2 members (2-Ton, JW51),
67
Mod | | | Forums66 Topics128,055 Posts1,055,783 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 23 New Guy | | New Guy Joined: Dec 2007 Posts: 23 | Is the barn door lock the same as side door lock? If it is not can it be made to work? If it can be made to work what needs to be done? Thanks.
Don 1950 Chevy Panel Delivery. Purchased in 2008 that was in a family for 35 years. Restomodded in 2006.
| | | | | Joined: Dec 2007 Posts: 23 New Guy | | New Guy Joined: Dec 2007 Posts: 23 | I have already altered a door handle and fitted it. I am talking about the lock itself. Don
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | The lock itself is the same, but attached to the lock is a rod that goes into the latch. that is different. So if you have the orignal lock, you can disassemble it and use the orignal locks rod. | | | | | Joined: Dec 2007 Posts: 23 New Guy | | New Guy Joined: Dec 2007 Posts: 23 | This is the answer I needed, thanks. So many times I have traveled down the path my mind has led me, only to find myself in deep doodoo. Reading and searching this forum has helped me greatly.
I have the original lock, but the key is long lost and I can't find an old enough locksmith to rekey it. So I will buy a new door lock and refit for my back door. Thanks, Don
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If the lock has a code number you can have a key cut to that. I know the push button locks were stamped but can't remember if back door one has it or not. | | | | | Joined: Dec 2007 Posts: 23 New Guy | | New Guy Joined: Dec 2007 Posts: 23 | When I get it out I will look for the code...but after all these years it may have been rekeyed...but worth a shot. Thanks
| | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | BTW Don, the rod is very easy to change. It is mearly clipped to the shaft of the lock cylinder. | | | | | Joined: Dec 2007 Posts: 23 New Guy | | New Guy Joined: Dec 2007 Posts: 23 | Thanks! I thought that I had read that somewhere but could not find it. I changed my rear handle and altered the shaft for that...came out perfect. My truck was in a shop accident a few weeks ago. In the shop for some front suspension work and was being moved and the brakes failed. Smashed up my front pretty good and scratched another trucks tailgate. My front end is lowered and my front went under the bumper of the other. Hagerty is great!
