1 members (Forty9), 64 guests, and 2 robots.
Topics128,043
Posts1,055,610
#934005 04/08/2013 3:12 PM
Is there a configuration of SBC that can be installed with an automatic transmission in a 1952 AD that does not require changing the original steering system. This has probably been answered before but I can't locate it and need to get my plans in order.
Usually the exhaust manifold on the drivers side is in conflict with the original steering box . Some chevy manifolds go up along the valve cover instead of down right away (if that makes sense) and these help on clearance , Also I have seen something about moving the steering box outward - away from the engine alittle bit. Most likely the engine/trans. will have to be offset towards the passinger side a bit instead of being centered exactly in the frame.
I think they refer to those manifolds as "Ram's Horns"...
fairly inexpensive and in reproduction in a couple of places
Squire #936346 04/17/2013 8:07 AM
I have ramhorn manifolds on my truck now {with the rack and pinion ) but on another truck I built (with stock steering box) I used 1955-1956 265 manifolds . They go up from the exhaust ports (like the ramhorns) but the "dump" was between the 1st and 3rd exhaust ports - which cleared the steering box . I think there was a similar manifold used on some '80's chevy cars also.
