3 members (delky, Hotrod Lincoln, Rich'sToys), 78 guests, and 0 robots.
Topics128,049
Posts1,055,740
#933840 04/07/2013 9:35 PM
I was just wondering if i can just run pump gas in my 3800 or if i should be using a lead additive. Also wondering what is the best type of oil to run in the engine? Its all stock.
stormsoneton #933922 04/08/2013 7:02 AM
i run straight gas in all three of my trucks. on occasion i drop some MMO in just to stimulate my brain yahoo i dont have a clue if it helps the motor but it hasnt hurt.
since i have had all my engines rebuilt i run shell rotella 15-40.
the oil question is a great debate. what's the condition of your engine and how dirty is it inside headscratch
stormsoneton #933924 04/08/2013 7:06 AM
Also, if non-detergent oil had been used, you could have sediment in the pan. I'd pull the pan and clean it out before using modern multi-grade "detergent" oil.
stormsoneton #933958 04/08/2013 11:06 AM
Im not sure of the condition of the inside of the engine i just put new plugs and belts and hoses and plugs and wires. It runs good just wasent sure on the oil and gas
Moderated by  Dusty53
