5 members (MRMEROTH11, Eisenholtz, TexasA&M48Truck, Wickedbass, Gdads51), 66 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
#933832 04/07/2013 9:07 PM
can i start working on my brake system before the truck actually needs them or should i finish the drive train and engine first??
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Materman #933833 04/07/2013 9:11 PM
Leo Offline
Moderator
Moderator
I did my entire brake system when I had a rolling chassis.
Materman #933848 04/07/2013 9:48 PM
I finished my brake system before anything else.
No one says you have to have any one system done before the other, however, it does help to have most of the major ones done before that first test drive.
Materman #933853 04/07/2013 9:55 PM
back yard wrench turner
I did my brakes before the motor, trans were installed. Then installed the motor and trans since the pedals mount off the trans. After that I did the brake lines and ebrake.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Materman #933855 04/07/2013 9:56 PM
Make it stop then make it go.
Materman #933858 04/07/2013 10:02 PM
When I was younger I always built the motor and spent money on everything else first and drove the truck with less than great brakes . These days brakes are always job 1. As I have aged my priorities changed. :>)
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
Materman #933878 04/07/2013 10:35 PM
also, will the master cylinder rebuild kits for the little trucks fit the 1.5 ton master cylinder in my truck?
Indy wink
1949 Dodge Coronet
1969 GMC LWB pickup
1972 GMC Sprint
Materman #933939 04/08/2013 9:19 AM
Riding in the Passing Lane
The brakes & fuel system are systems you are going to have to go through. I think it is best to get the engine running first & make sure the clutch & gears work. Then you will be able to make a plan.
1972 Chevy c10 Cheyenne Super
