2 members (Otto Skorzeny, 5 Window 9434), 130 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
#933354 04/06/2013 1:31 AM
I have a 53 1/2 and would like to put a new radio in. What is involved in changing to a 12v and what are the benefits? Thanks!
Scott60 #933373 04/06/2013 7:12 AM
Depending on the power-draw of your radio, 6v-to-12v converters are available ($50-$150 or more).
Stovebolt.com has a good Tech Tip on 6v to 12v conversion.
If you are going to want to use a lot of 12v accessories, the 12v conversion would make this easier. If you want to stay more "original equipment" and you will not want to use many 12v accessories, 6v works fine, as long as you have the correct size battery cables and ground straps (and clean connections).
12v requires lower-gauge wiring, so your 6v wiring will work fine in a 12v conversion.
Scott60 #933485 04/06/2013 7:38 PM
So a 12v battery will work on a 6 volt battery?
Scott60 #933494 04/06/2013 8:18 PM
Quote
Do you mean 12v radio with a 6v electrical system?
Yes, with a 6v to 12v converter.
Scott60 #933610 04/07/2013 8:48 AM
This could be the answer. I have a 6 v system. I would like a radio-12v. Trying to decide if I should change truck to a 12v battery ( and all that entails ), r/r 6 v generator with an alternator ( and all that entails ) or you are saying I could use a "6 to 12 converter" . That would seem the easiest/ least costly. My intention is a rebuild to drive around town and would like a radio. Thanks for your advise!
Scott60 #933774 04/07/2013 5:26 PM
Ex Hall Monitor
Ex Hall Monitor
You can get original 6v radios.....if you don't mind receiving nothing but AM. grin This is the working 6v in my '38.
Scott60 #933808 04/07/2013 7:55 PM
Nice. Where did you get yours?
Scott60 #933871 04/07/2013 10:16 PM
I see Ecklers Chevy parts has a power booster 6-12v for $100.
Scott60 #933915 04/08/2013 5:13 AM
Scott60,
What is Eckler's part number for the "power booster"?
Scott60 #933929 04/08/2013 8:21 AM
Ex Hall Monitor
Ex Hall Monitor
I got mine on ebay. You can also find 6v to 12v boosters on ebay.
