4 members (Gdads51, Ponchogl, DadsFirstPickup, stlcardinalsguy), 121 guests, and 1 robot.
Topics128,054
Posts1,055,782
#93370 11/04/2005 5:19 PM
Junior Member
Junior Member
My glow plugs just stopped working on my 83 chevy 6.2 diesel they were working fine until I parked it for a couple of months and tried starting it. Any diesel experts out there?
#93371 11/04/2005 6:14 PM
V
V Offline
Your glow plug relay is probably frozen. Sometimes a couple of light taps with an appropriate tool will free it up. Otherwise you may need to replace it.
#93372 11/05/2005 12:16 AM
Junior Member
Junior Member
I'll check it out.
#93373 11/07/2005 11:06 PM
Junior Member
Junior Member
I tried a new relay but still no glow plugs any other suggestions . I have replaced batteries starter and relay. Also I tried a different controller that is located on the right rear side of motor.
#93374 11/08/2005 9:10 PM
V
V Offline
Test the glow plugs. They should have a low resistance (0-50 ohms typical). Test the voltage at the glow plugs - you should see close to battery voltage (12v) at the glow plugs for 15-20 seconds.
If you just want to get it started, first plug in the block heater (if you have one) to get it good and warm, then put a jumper between the battery and the glow plugs for about 15 seconds - then crank.
