1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#93370 11/04/2005 5:19 PM | Joined: Oct 2005 Posts: 10 Junior Member | | Junior Member Joined: Oct 2005 Posts: 10 | My glow plugs just stopped working on my 83 chevy 6.2 diesel they were working fine until I parked it for a couple of months and tried starting it. Any diesel experts out there? | | |
#93371 11/04/2005 6:14 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Your glow plug relay is probably frozen. Sometimes a couple of light taps with an appropriate tool will free it up. Otherwise you may need to replace it. | | |
#93372 11/05/2005 12:16 AM | Joined: Oct 2005 Posts: 10 Junior Member | | Junior Member Joined: Oct 2005 Posts: 10 | | | |
#93373 11/07/2005 11:06 PM | Joined: Oct 2005 Posts: 10 Junior Member | | Junior Member Joined: Oct 2005 Posts: 10 | I tried a new relay but still no glow plugs any other suggestions . I have replaced batteries starter and relay. Also I tried a different controller that is located on the right rear side of motor. | | |
#93374 11/08/2005 9:10 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | Test the glow plugs. They should have a low resistance (0-50 ohms typical). Test the voltage at the glow plugs - you should see close to battery voltage (12v) at the glow plugs for 15-20 seconds.
If you just want to get it started, first plug in the block heater (if you have one) to get it good and warm, then put a jumper between the battery and the glow plugs for about 15 seconds - then crank. | | |
