3 members (KEVINSKI, Tom McGrath, 59 fleet), 110 guests, and 1 robot.
Topics128,034
Posts1,055,552
I have been looking for a while for the part number from pertronix for the kit to convert my 46 2-ton. Anyone installed one that they still have the box with the part number?
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
3B Offline
Hy RDomeck,
six volt negative ground p/n 1167N6
six volt positive ground p/n 1167P6
twelve volt negative ground p/n 1167
twelve volt positive ground p/n 1167P12,
hope that helps.
Wow. Thanks for that. I should have mentioned it was for 12V negative ground. I'll get it ordered tomorrow!
Randy Domeck
[email protected]
317-258-0039
3B,You're THE MAN! Thanks for the info.!!
Mo' Tater
3B Offline
Hy Guys, I should make you aware that these part numbers are for the 1941-1953 distributors, if you require the numbers for the newer distributors, just ask
In case any one wants/needs to know the kit from my local Carquest store cost $89. Also the points, condenser, cap and rotor #'s are......
Points 50-3529
Rotor 51-5571
Cap 51-1597
Condenser 50-1617
I provide this because it took a few tries with them to get the correct parts. You can generally have the #'s cross referenced with any parts supplier!
Randy Domeck
[email protected]
317-258-0039
What about your coil?
The coil (and maybe the ballast resistor, depending on the coil) are important considerations with a Pertronix ignition.
