| | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I have been looking for a while for the part number from pertronix for the kit to convert my 46 2-ton. Anyone installed one that they still have the box with the part number?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy RDomeck, six volt negative ground p/n 1167N6 six volt positive ground p/n 1167P6 twelve volt negative ground p/n 1167 twelve volt positive ground p/n 1167P12, hope that helps. | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Wow. Thanks for that. I should have mentioned it was for 12V negative ground. I'll get it ordered tomorrow! | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | 3B,You're THE MAN! Thanks for the info.!! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Guys, I should make you aware that these part numbers are for the 1941-1953 distributors, if you require the numbers for the newer distributors, just ask | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | In case any one wants/needs to know the kit from my local Carquest store cost $89. Also the points, condenser, cap and rotor #'s are......
Points 50-3529 Rotor 51-5571 Cap 51-1597 Condenser 50-1617
I provide this because it took a few tries with them to get the correct parts. You can generally have the #'s cross referenced with any parts supplier!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What about your coil?
The coil (and maybe the ballast resistor, depending on the coil) are important considerations with a Pertronix ignition.
