2 members (78buckshot, NJC),
99
Mod | | | Forums66 Topics128,149 Posts1,056,819 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | For those of you who didn't see it in the "what did you do today" thread, you can see my new cab at my blog below.
I'm psyched! I can’t believe how nice it is… I’m half tempted to buff out the paint and touch up the scratches…
One thing I have noticed so far is that it has two bolts front to back on the core support to mount to frame. Mine had a single bolt. May have to make an adjustment there.
Tj
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | For those of you who didn't see it in the "what did you do today" thread, you can see my new cab at my blog below.
Tj | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and I'll add the suggestion for Tj to change the drop box below to "Using HTML & UBBCode" when pasting text in from another app
Bill | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | cab looks to be in good shape,
what size truck did the cab come off? There are differences in the schackles
good luck | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | It's off of a 6500 going on a 3800.
going to fab the 8" or so extensions to turn my frame into a 4100 frame essentially. that's the plan for now anyway.
i think my frame has the two holes I need for the radiator core but i have to double check. rear cab mounts different? i have both my 3800 shackles and the new cab has the original ones too | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The differences could be between the small cab shackles and larger cabs. Might not effect your project. | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | good to know. ill check on that.
so even though all conventional trucks used the same cab, some had different shackles than others? maybe because the 1/2 ton frame is different in that area. i think it"s wider. | | |
